compress algorithm
  • 2 fhreagra
  • 1 leis an bhfadhb seo
  • 4 views
  • Freagra is déanaí ó dmitriy11993
please advise which compression algorithm is used when saving browser console command history in the ~/.mozilla/firefox/xxx.default-release/storage/permanent/indexeddb+++fx-devtools/idb/xxx.sqlite ?
There's no compression. It's just a uncompressed sqlite database file. You need a sqlite db editor and learn some SQL to use this file.
Thanks for the answer.
If so, why doesn't the size of the sqlite-file change (it remains equal to 48 kilobytes), no matter how many commands I enter in the console? The size of the sqlite-file does not change even after adding a few megabytes of text to the console.
I was browsing the contents of the object_data table using DB Browser for SQL: http://i.imgur.com/T2sIsJu.png
